How to paste the charts shown in Labview into a powerpoint slide show?
I'm using LABVIEW to do some instument control and data acquisition, actually, we are doing some Bio-mechanical study on tissues( a piece of skin), we use motors to strech the skin in two directions and use a
camera to monitor the motion of spots attched on the tissue, the strain of the tissue is dynamically shown
on the screen, My problem is that I need to show this dynamic process (of the strain) in a presentation (with out the hard ware, it means I could not show the real experiment), How can I save the dynamic strain process ( Charts) in my Powerpoint slides?
(3,047 Views)
You can copy Labview front panel charts by selecting the chart and then using Control-C and paste them into Powerpoint using Control-V.
- tbob
Inventor of the WORM Global
(3,047 Views)
But in this way i can not present how these plots were made, which means the drawing progress of these plots when Labview was running.
(3,047 Views)
I don't think that is possible. You would have to be running Labview from inside Power Point. Can you possibly capture the chart at different times, in different drawing stages, and perhaps place these graphs in Power Point?
- tbob
(3,047 Views)
You should use invoke node and capture images. Best is place your chart in a tab control, and see the example ive attached. If you want it at specific times, have a loop outside the diagram i sent and do your stuff. LEt me know how it goes.
Kudos are the best way to say thanks 🙂
(3,047 Views)
