How to perform Modal Parameters Extraction with LabVIEW 2011 ?¿
We are developing a modal analysis study with an impact hammer and a triaxial accelerometer. Our problem is the version of LabVIEW, because the modal parameter extraction package needs the 2009 version, and we are working in 2011. It is possible, in any way, to use V2011 to perform modal parameter extraction ?¿?
(3,218 Views)
A bit late and you probably found a solution...
Do you have the sound and vibration toolkit?  There are functions available within the toolkit to assist you.
(3,066 Views)
