How to perform octave analysis and THD on frequencies greater than 22KHz
I have 7.0 and that last version of sound and vibration toolset. The THD and octave analysis only goes up to 22KHz. Is there a way to increase the vi's to perform analysis up to 1MHz or higher?
-Ted L
(3,229 Views)
If you use the SVT Fractional-octave Analysis [ANSI] VI instead of the SVT Third-octave Analysis [ANSI] VI, you can set the frequency range to your desired range as opposed to being limited by the available choices in the third-octave analysis VI.
There is nothing that should prevent you from measuring the THD up to any arbitrarily high harmonic. Without seeing your code, I can't give much more help than that.
Attached is a VI that simulates a 10 kHz square wave for 100,000 samples at a sample rate of 1 MHz and performs third-octave analysis and measures the THD and individual harmonic components up to the Nyquist frequency (500 kHz).
Hope this helps,
Doug
Doug
Enthusiast for LabVIEW, DAQmx, and Sound and Vibration
(3,229 Views)
