How to place a Reference Plot inside Acquired Data Graph?
Of course you can't see it. You have a regular waveform graph in your program. As I said, I used an XY graph like the others you have. You have to get the separate columns from the dynamic data returned by the Read From Measurement File first. You can do this with the Split Signals or convert the dynamic data to 2D DBL and use the index array function to get each column.
Message 11 of 16
(970 Views)
Ok, so I got the graph to display behind another transparent graph background. So now my question is how can I create a button to hide or display the reference graph in the back?
Message 12 of 16
(954 Views)
You create a button by going to the front panel and selecting a button style you like. If you were to change to an architecture based on the event structure, I'd say add a value change event for the button with a visible property inside the event. If you don't change it, just wire the Boolean to the visible property of the graph.
At some point, you really want to redesign the program. The use of multiple graphs stacked on top of each other is going to be a performance hit. Any one of your graphs can be used for displaying all of the plots.
Message Edited by Dennis Knutson on 07-21-2008 08:43 PM
Message 13 of 16
(941 Views)
I definitely don't have enough knowledge of LabVIEW to redesign the program (I just downloaded the driver from this site so I dont know much how it works), but I want to be able to get the plots to display on the same graph to make things a bit tidier.  I was trying to do it all of today, but I couldn't figure it out from what was provided so I settled for the superimposed graph.  I'm willing to give it a shot tomorrow though if I can get some more information.  If I were to get the plots to display on the same graph, would the hide/display function still be done the same way?
Thanks some more
Mike
Message 14 of 16
(929 Views)
What would I have to do to join the channel 3 graph with the channel 1 graph?  I had a boolean wired in to hide or display the graph, but I had to put it inside a while loop for it to work.
So in the end I would like for Channel 1 and 3 to be on the same graph, but for Channel 3 to have a boolean to display and hide it.  And the simpler the explanation the better Smiley Tongue
Message 15 of 16
(918 Views)
Hi Mike,
use the build array function and connect both to it.
Mike
Message 16 of 16
(905 Views)
