05-10-2010 08:16 AM
hi, everyone
I am a kind of beginner of Labview and now I encountered a trouble that I do not know how to play a video chip in Labview front panel
The funciton I need is very simple, just play the video automatically when the VI is running.
Another thing is the version of Labview I use is Labview 2009 and I found there is some differencs on WMP property between this and other version. I will show you in pictures below.
Thanks in advance for giving me a hand.
Louis
05-10-2010 08:23 AM
Louis,
simply write the path+videoname+extension to the video to the property "URL" .
hope this helps,
Norbert
05-10-2010 08:54 AM
Firstly, thanks for you reply
But is it convenient for you to draw a simple block diagram for me since I still cannot find a way to connect those stuff.
05-10-2010 09:16 AM
Right click on your control on the block diagram to create a property node, then you might see the URL property! ![]()
(Haven't tried it, just noticed you are playing with a control, not an indicator)
James
