How to play a wave file through the DAQ board?
Hi there,
we want to play a wave file that is saved on the harddrive via the DAQ board. Means we want to connect a amp to the analog output of the DAQ to amplify the sound and play it through a speaker.
We couldn't find any VI that does that. Can anybody tell us how to play a wave file, or perhaps even send us a VI that can do that?
Thanks a lot for your help
Martin - Physical Optics Corporation
(2,692 Views)
Hi Martin,
The only example that I could find on how to do this was using our older Traditional DAQ drivers version 6.9.3.  If you're using Traditional DAQ drivers, the vi can be found here.  The example reads a 8-bit mono .wav file (an example .wav file is included in the .zip file) and writes it to the analog out of your DAQ card.  I've updated the example to work with our newer DAQmx drivers and attached it here.
I hope this helps,
Paul C.
Message Edited by Paul C. on 08-14-2007 05:47 PM
(2,669 Views)
