Showing results forĀ
Search instead forĀ
Did you mean:Ā
How to plot data sent through serial port by controlling knobs simultaneously
Hi
I want to plot data by controlling two knobs simultaneously and plot the values according to my control using serial port communication but the problem is that the plot on the graph alternates between the two controls its not changing according to my control for eg if i move the knob1 to 1000 and knob 2 to 4000 these values alternate on the graph i have placed a select control still the problem is not solved can u help me please thank you in advance
With regards
Samatha
Message 1 of 13
(5,556 Views)
Hi samatha.k,
can you upload your vi?
Mike
Message 2 of 13
(5,555 Views)
i have attached my vi please find it in the attachments thank you in advance....
Message 3 of 13
(5,546 Views)
Run the VI again and when the values are plot on the graph, go to Edit -> Make Current Values Default. Then post the VI.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
Message 4 of 13
(5,533 Views)
i did as u said
Message 5 of 13
(5,528 Views)
Hmm there is nothing on the chart. Is it possible for you to post a screenshot of the chart after you run the VI?
Adnan Zafar
Message 6 of 13
(5,525 Views)
Message 7 of 13
(5,520 Views)
Your VI CANNOT plot more than once since you do not have the code in a loop. Do NOT use the run continuous button. I also fail to see how you think anything can be simultaneous since you are using the same port. The for loop you have is also very strange. That doesn not belon there at all.
Message 8 of 13
(5,501 Views)
i know there is something wrong with my code because i am new to labview i am just trying to build to new VI anyways so what do i need to do now pls tell me
thank you in advance .....
Message Edited by samatha.k on 05-03-2009 01:04 AM
Message 9 of 13
(5,482 Views)
Thank you sir i have got the solution i have put whole code under while loop and placed two cases..............
Message 10 of 13
(5,471 Views)
