How to plot different curves with a circular rotation
Hello, it's a little bit difficult  for me to explain, I'm not the best in Englich.
I have different curves and I want to know if its possible to plot them in a 3D graph with different rotation.
The idea is to set the rotation for each curves and them plot all together in a graph. I put a picture as attached file so you can visualise my idea.
I try with many different Graphs but I don't now how to make this particular plot
Thanks for the help
(3,495 Views)
Hi Jardin,
You may be able to get that functionality by creating a mesh plot (look up mesh plot or 3D plot in the example finder). You could multiply different plots by a rotation matrix.
Alternatively, if the LabVIEW plotting does not have the features you want, you might look into this advanced plotting toolkit for a bit more:
https://www.ni.com/en/support/downloads/tools-network/download.advanced-plotting-toolkit.html
(3,470 Views)
Use a "3D line graph" and use a different plot ID for each curve.
(I assume you don't have problems with the math itself.)
(3,463 Views)
Thanks !! I will try with this toolkit
(3,454 Views)
