How to plot temperature and voltage using Mixed Signal Graph
I am using the NI cDAQ-9178, module NI 9214 (temperature) and module NI 9201 (voltage). My program allows the user to select from 3 different tasks, Temperature Masurement, Voltage Measurement or both. When selecting the task for both Temperature and Voltage Measurement, I was plotting all channels onto the same graph. I've been asked to separate temperature and voltage channels and plot onto one split graph, using the same x-axis. I've tried stacking, but could not control where each channel plot went. I think that the Mixed Signal Graph would work best. All is working and all channel data is saving to files, but my plots are not showing on the graph, although I can see the graph scale numbers changing. I think that I may be using the cluster incorrectly. Can someone tell me what I am doing wrong?? I've selected the "Plot Visible" option, but plot still is not displayed. I have attached a zip with all necessary VIs to run my program. The main VI is "Voltage_Temperature_SingleTask_Measurements_MAIN.vi" ... but all must be downloaded for the program to work. Please help ... thanks. Smiley Sad
(5,768 Views)
I can't open your VI but here are a couple of thoughts (if i am understanding your question correctly):
1. Is Autoscale turned on for your Y-Axis
2. Is your plot color transparent?
aputman
(5,755 Views)
The Y-Scale is grayed out, so I cannot select AutoScale ... but if I go into properties, AutoScale is checked
I don't see any transparent options, when I right click and select "Color". My current default colors are blue and red.
Try the zip file now
(5,744 Views)
Hi mzlhb,
you have just one (1) sample in the waveforms you read from DAQmx device, so the graph will show "nothing" according to <our plot properties.
Change the plot style to show dots insteadof/additional to interpolation lines -  or read more than just one sample per DAQmxRead!
WTF you are doing with this SplitSignal function on your waveform array? Why not use a simple IndexArray?
(5,732 Views)
GerdW:
GerdW,
I'm quite new to LabVIEW, so I don't know how to use the Index Array in this application. There is a NOTE in the CONTEXT HELP for the Mixed Signal Graph that states that the bundle must be used. I couldn't figure out another way to separate my voltage and temperature, except with the split signal function. Can you explain how I should use the Index Array in this case. I connected the Index Array to the output from the DAQmx Read, after reading your post and everything stopped working. Thank you
(5,723 Views)
Accepted by topic author mzlhb
Hi mzhlb,
I only complained about the expressVIs.
Why not use simple IndexArray function to get bots waveforms from your waveform array? (I simulated your DAQmxRead with SigGen functions.)
(5,712 Views)
Thank you GerdW. That worked perfectly
(5,705 Views)
