How to plot this..?
x = 0:0.5:1
params = [0 0.5 1]
for i=1:length(x)
if x(i)<params(1)
y(i)= 2 * abs(x(i) - 0.5);
elseif x(i)<params(2)
else x(i)<params(3)
end
end
out=y';
plot(x,out)
I have a this simple program.
How to plot this in LABVIEW block diagram or Front panel.?
How the plot will look like is attached here.. please help..
(4,404 Views)
What have you done so fare ?
How much do you know about LabVIEW ?
I will give you some clues: For loop, Autoindexing, Ramp, basic math, and a xy-graph.
(4,381 Views)
Hi means,
                         Its very simple but tell me why line 5,7,9 statements are same, It is else part so it should be different from each other right ?
Doesnot make any sense.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(4,352 Views)
It will be same because
length(x)= 3
so if x(1)<params(1)
y(1) = 2* abs(x(1) - 0.5)
and so on..
Here i will be maximum 3 and same params is also 3
(4,334 Views)
I am totally new to labview and want to enter in this field.
Before this i just seen a demo from NI person that taking one knob and connecting it to meter..
Ok.. I will try now with the elements you given and will come back here..
(4,333 Views)
I think Ranjeet meant that since the equasion in the cases is identacle you don't need the If.  Or For loops or params[] at all and a postage stamp size BD is all that you need.
(4,299 Views)
