How to plot two bundled clusters in one graph?
I have an instrument that collects Current readings. I press the Run1 button, and it measures the current at different voltages on a sample. I press the second Run2 button  and it also measures the current at different voltages except this time the sample is illuminated. Both Run1 and Rund 2 generate bundled clusters, which I then plot. What I want is to super-impose these two plots. The problem is  I created/generatde these two bundled clusters (X and Y) separately using two case structures (latch). I try to get the clusters outside the loop, but there's the FALSE condition I have to deal with. How do I get around this?
(4,179 Views)
Give this to build array and output of build array give to graph.
This way should work and bundle should be of time & parameter to be plotted (Make sure)
Let me know.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(4,166 Views)
Hard to follow your code description, why not post some code?
A diagram tell more than thousand words 😉
That way you might get the fastest help.
Greetings from Germany
Henrik
LV since v3.1
(4,163 Views)
Here's the VI. Technically I want the bundled array and plot graph out of the Case Structure. But I can't do that. There's a FALSE condition I hae to deal with.
(4,124 Views)
I am attaching you one image. Look at that.
Hope this will help you
--Ranjeet
(4,118 Views)
The shift register is your friend.
I did not have the instrument VIs so I used Diagram Disable to make a runnable VI.  I substituted a sine function for the data source.
Lynn
(4,098 Views)
