How to plot two points in xy graph?
Hi, I need help to plot 2 different points at 2 different coordinates. Can anyone help me with this? If possible, please provide me a vi which also calculate the distance and angle between the 2 points. Thank you
Message 1 of 11
(5,210 Views)
NI Example Finder:  XY Graph.vi
Message 2 of 11
(5,202 Views)
If you have the context help window open and you hover the cursor over the XY chart terminal on the block diagram you will see how to feed data to the XY graph:
If you click on the Detailed Help  link you will be taken to the LabVIEW Help page that discusses XY Graphs. That section also contains buttons for opening the examples on XY graphs that show you how to plot data on XY graphs.
Have you done any of this?
Message 3 of 11
(5,199 Views)
try this
Message 4 of 11
(5,188 Views)
Here it is.
But do you actually need that plot?
Message 5 of 11
(5,177 Views)
aias, tq for ur help... but i cant open the files as they are in 2010 version, whilst im using 2009 version. can u plz convert the files?? thanks
Message 6 of 11
(5,160 Views)
yes, wait 1 minute
Message 7 of 11
(5,111 Views)
Accepted by topic author one3seven5
her they are
Message 8 of 11
(5,108 Views)
if you want graph make sense - open properties, scales, and enter the limits for each axis, instead of autoscaling, for example 0-100
Message 9 of 11
(5,102 Views)
thanks for ur help. however, there is a small percentage of error. can you please explain this to me? thank you
Message 10 of 11
(5,053 Views)
