How to plot with scilab script node in LabView?
Hello LabVIEW-Community,
I hope this subject is in the right section.
For enhancing my level of automation I would like to call functions in the scilab node of Labview which I have already used before in Scilab. A big part of these functions is to plot curves. Unfortunately plotting don't seem to work.
I have the Scilab-toLabVIEW-Gateway and scilab installed. Also I use the 2015 version of LabVIEW.
I tried it with two (32bit & 64bit) systems.
I know it is possible according to this video at about 16:30
https://www.youtube.com/watch?v=dimFz2d6aAM
I used the same example VI but it didn't work.
Has anyone an idea?
Thank you in advance for your help!
Marco
(3,949 Views)
Hi Marco,
Did you ever figure this out, I saw the same video. I can find a post from 2008 that stated ploting is not supported but nothing newer.
(3,708 Views)
Add me to the list as well. Seems to me any time I call any function related to plotting the script fails, but I'd like to know for sure.
(3,200 Views)
