How to press a botton and a panel become invisible?
Dear all,
I attached a file the version is 8.2. My question is how can I press the botton "Panel A", the Panel named A become invisible or visible.
And so on. Thanks!
(2,844 Views)
You could use seperate tab controls for each panel.  If you make the background color of the tab transparent it will not look like the code is on a tab.  You can then control the visibility of the tab controls using their property nodes.
(2,826 Views)
Thanks for reply. Why I want to use this method is because I have a table in each panel.
I want to drag item from Panel A to Panel B. And so on.
So I must use this function.
(2,806 Views)
Your question can be interpreted in several ways, here are two interpretations and possible solutions.
Do you (1) simply want everything in panel a to become invisible or do you (2) want to programatically move the splitter left so panel A has zero width and panels b,c,d, move to the left?
For (1), make "visibility" property nodes for all desired objects in panel A. Show or hide them using a boolean.
For (2), create a property for splitter2, select property "splitter position", and programmatically feed it a lower number so the spliiter bar moves left.
Now repeat for the other panels/splitters accordingly.
(2,799 Views)
