How to prevent right click in a web-browser
Hi there
I'm using a web-browser object to view a HTML file. How can I prevent a user from right clicking on this object.
It seems like the object isn't behaving as a normal indicator or control, it's always untop so I can't put anything transparent over it, and using an event structure with "Mouse Down?": Discard = True doesn't work either.
Is there another way to view a HTML file in LabVIEW?
Andreas - Going to NI-WEEK 😃
(2,419 Views)
Hi Lind,
you can use the "Mouse over event" this works. And if it occurs you can use a user32.dll function to block the mouse key. After the mouse leave this area, you can activate it.
Mike
(2,387 Views)
