How to prevent the column size from changing when using Excel easy table?
When I write data using Excel easy table, the size of the column in the Excel file is changed.
How can I keep the existing settings?
(2,218 Views)
Hi Kwon,
several options:
  1. Don't use ExcelEasyTable, when its behaviour doesn't fit to your requirements.
  2. Read the column width, then apply ExcelEasyTable, then set the column width to its old value.
  3. ...
(2,157 Views)
