How to print a report in MS-Access from Labview?
Good morning,
We have our system running properly but we want to provide the user just one GUI to execute the measurements and print the report, we keep using ms-access beacuse facilitate the data  integration with the res of the areas of tha company.
Miguel
(2,443 Views)
Basically, you are going to have to communicate with Access via ActiveX and tell it to print the report for you. If you don't know the Access object model a good approach is to find an example on how to programatically run a report in some easy to read text language like VB. While you will not want to follow the exact program structure too closely, it will at least tell you what properties and methods you will need to use.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,427 Views)
