How to print on Dymo LabelWriter with Labview
Accepted by topic author slarve
@slarve wrote:
Will look into that Dymo Label software. The SDK you mean?
I have SDK installed, old Dymo Label version 7.7 and new Dymo Connect v1.4.6
What I meant is upgrading your 7.7 version to 8.7.4 because I suspect for the SDK v8 to work the corresponding Dymo Label Software version needs to be installed.
  • Go to their software support page: https://www.dymo.com/support?cfid=dymo-compatibility-chart (choose to continue on the US website)
  • Search by software for DLS 8.7.4
  • Download & install
  • Run the DLS, if the label editor appears and you have a connected printer exit the program
  • Run your VI again (this was needed on our machines)
Message 11 of 23
(1,589 Views)
Found v8.5.4 of Dymo Label software in a netherlands dymo page, but it still gives me the same error.
Will try your suggestion now. Did not find the old versions on that Dymo page
Message 12 of 23
(1,573 Views)
Now it works! Thanks Alot
Was v8.7.4 that was missing!😅
Message 13 of 23
(1,563 Views)
Are you able to share your code, i am currently working through this myself
Message 14 of 23
(1,315 Views)
I think my issue has to do with the SDK, when i run the 8.7 DLS it says it needs to add a printer and that crashes and never loads the printer. I can see the printer in DYMO Connect but not DLS. Will try on a different computer to see if it is just and issue with my system.
Message 15 of 23
(1,300 Views)
Which DYMO printer version are you using? We have found newer versions are not supported using Dymo Label Software only Dymo Connect (https://www.dymo.com/support?cfid=online-support-sdk).
Unfortunately I have been unable to create the right constructor nodes using any of the DLLs in the DYMO Connect SDK. This may have changed with newer versions of the SDK. It could also require a @RolfK level of expertise.
Message 16 of 23
(1,289 Views)
My customer is attempting to use a Dymo labelwriter 5xl
Message 17 of 23
(1,278 Views)
What printer have you had success with?
Message 18 of 23
(1,272 Views)
This LabelWriter 450 works. We also have some 5x0 versions, not sure if 500 or 550. The Turbo variants also work.
Message 19 of 23
(1,267 Views)
This is from ny notes:
Install v8.7.4 av Dymo Label Writer
Install v7.x av Dymo label Writer
Install SDK til Dymo
And then it worked!
Message 20 of 23
(1,254 Views)
