How to print picture
@田淇予 wrote:
Thank you for your reply, butI want to trigger the printer by clicking a button when the software generates pictures.
Use event structure to catch the button click event.
in the event, call "System Exec.vi" with
mspaint.exe -p imagePath
as command line.
George Zou
Message 11 of 22
(1,192 Views)
See attached VI.
George Zou
Message 12 of 22
(1,173 Views)
try to  create a subvi with the code I shared before and pass the file path into it and setup the vi to print the  front panel after execution.
Include that subvi into the event structure you shared instead of using the System exec.
Message 13 of 22
(1,156 Views)
I know that I can print pictures in the above way, but it will generate a word file.
Is there any way to print pictures directly as below instead of indirectlyhelp.png
Message 14 of 22
(1,149 Views)
Thank you for your suggestion. I have tried it. It can print, but I want to use the printer directly to output the label, which requires me to choose againhelp.png
Message 15 of 22
(1,148 Views)
  • please
  • Looking forward to your reply
Message 16 of 22
(1,148 Views)
This is an effective method, but I do not want to save the image locally, but can print out when generated, if you have a better way, looking forward to your replyhelp.png
Message 17 of 22
(1,144 Views)
like this
Message 18 of 22
(1,144 Views)
  • Can you give me an example code? Thank you very much
Message 19 of 22
(1,142 Views)
Message 20 of 22
(1,138 Views)
