How to produce a Logarithmic Sweep (Chirp) over a Frequency Band
Please find attached my work in progress. I made my current values default as you suggested and also tried to put an indicator for the sampling rate. It only worked when i made it a control. Please advise.
Thank you.
Daniel
Message 41 of 44
(1,259 Views)
Daniel,
The sampling rate definitely needs to be a control.
In looking at the data, it appears that the input spectrum is flat up to 1000 and then drops off rapidly after that.  OK. You have a sampling rate of 16384 and stop frequency of 0.0625.  The highest frequency in the chirp pattern is the product fmax = 16384*0.0625 = 1024.
Anything above frequency 1024 is relatively meaningless because it was not excited.  The magnitude of the transfer function drops from near 1 to near 0.1. The magnitude of the load voltage also drops to about 0.1 times its low frequency value.  So I think that part is basically working. The Phase transfer function appears to be a linear change with frequency over that range (after allowing for the 2 pi wrap).
Lynn
Message 42 of 44
(1,251 Views)
Lynn,
Thanks a lot. I have to do more work. The sampling frequency I had in mind was 32kHz. I wanted my Fmin and Fmax to be 0 and 2kHz respectively. Following your suggestion earlier, I divided 0 and 2k by 32k to get the 0 and 0.0625 that you see.
I wonder how to ensure this Sampling Frequency of 32kHz.
Message 43 of 44
(1,240 Views)
Daniel,
It looks like it has to do with the number of samples.  The default values saved with your VI had a sample rate of 16384 and the number of samples = 8192.
When I changed the number of samples to 16384, I get the spectrum of the chirp flat out to 2048.  I do not have time to work out all the math, but the number of samples in the pattern has an effect on the range of frequencies.
Lynn
Message 44 of 44
(1,234 Views)
