How to program NI myRIO to control and monitor climate chamber
Can anyone help me, i am not good with programming. Need to learn a lot. Anyone can guide me to program NI myRIO in order to use it as remote control and also monitoring a climate chamber?
(3,139 Views)
I would use the link below to start learning LabVIEW and myRIO basics.
http://www.ni.com/myrio/setup/getting-started/
Once you have an idea of how to use the myRIO, you should start looking into what sensors you may need for your project. The myRIO has a lot of analog and digital I/O connections but those themselves aren't going to let you control and monitor a climate chamber.
(3,124 Views)
Many climate chambers have an RS-232 communications port which allows you to communicate with the chamber to read the current values (e.g. temperature/humidity) and set them. The manual/documentation from the chamber manufacturer will provide details - some of them even have LabVIEW drivers (or use a standard like MODBUS)! To connect this RS-232 port to your myRIO, you will use one of the UARTS on the myRIO but these are at TTL (3.3V) levels so are not compatible with the RS-232 signals - you will need to use an RS-232 transceiver chip/circuit to convert the voltage levels so they are safe to use with the myRIO.
Of course - you also need to learn some LabVIEW - so take a look at some of the free tutorials/courses/webinars that are available first!
http://www.learnni.com/
https://www.ni.com/getting-started/labview-basics/
(blog)
(3,083 Views)
