How to program a 50 point look-up table in LabVIEW7 Express
I'm trying to write a VI to measure an analog input, compare the input values to the values in a preprogrammed 50 point lookup table, and produce the corresponding output value from the lookup table. Is there a "canned" VI I can use?
(2,957 Views)
I doubt that any canned program will do what you want but it should be quite easy to put your lookup values in an array and loop through the array comparing the elements to the data point. The index where the data matches can be used to select the output from a second array.
Lynn
(2,950 Views)
"Is there a "canned" VI I can use"
One? no. Two yes.
Threshold 1d array and interpoltate paired will do it.
Ben
(2,944 Views)
