12-14-2020 05:12 AM
Hello. I have to program a switch using cRIO 9039 and LabVIEW. This is my first time working with cRIO and I had been reading manuals and userguide but I don't find the information in order to make my first cRIO program. I would be very grateful if someone can write a program like the program I want to make so I can start learning about cRIO programming. Thank you.
12-14-2020 05:50 AM
12-14-2020
08:02 AM
- last edited on
08-06-2026
07:38 PM
by
Content Cleaner
So you read the CompactRIO Developer Guide
https://www.ni.com/en/shop/compactrio/compactrio-developers-guide.html
and you still don't know how to program an RIO application?
12-17-2020 08:14 AM
Im learning how to program cRIO with the NI 9403. All the tutorial I've found are for FPGA programs. Other tutorials use the Digital I/O as a double and I just can work with them as a boolean and I don´t understand why.
12-17-2020
08:40 AM
- last edited on
08-06-2026
07:38 PM
by
Content Cleaner
Hi Goku,
start with cRIO basics, like presented here.
Me neither. Never had any examples for digitalIO using DBL datatypes. Mind to link to those (bad) examples?
