How to program in LabVIEW to check if a vi exists in a *.llb file?
This should be very simple, but I cannot find a way to do it. Can somebody help? Thanks.
Ian
(3,193 Views)
if you want to do this in code then go to openG.org and download the commander you will get a host of file vi's that will do what you want. it is free and will also give you plenty of vi's to do lots of other things
Joe.
"NOTHING IS EVER EASY"
(3,181 Views)
Check out the VIs in this library (typical location):
C:\Program Files\National Instruments\LabVIEW 7.1\vi.lib\Utility\libraryn.llb
There are some good VIs to work with LLBs in there.  You may especially be interested in the 'Librarian List.vi'
-Khalid
(3,169 Views)
Khalid
This is what I am looking for. Thanks.
Ian
(3,142 Views)
