How to program keyboard to boolean?
I would like to press any button on my keybaord and have that button turn on and off an LED. How can I do this?
Message 1 of 14
(5,427 Views)
Event structure key down event (triggered when pressed) or key up (triggered when released)
Charles Chickering
Architecture is art with rules.
...and the rules are more like guidelines
Message 2 of 14
(5,424 Views)
Can I also do this with side arrow keys or letters?
Message 3 of 14
(5,422 Views)
Also what blocks shall I use? I have my event structure and down arrow programed with a boolean placed inside. The only way i can get it to lite up is connecting a display block to the Boolean, but I don't want to do that.
Message 4 of 14
(5,417 Views)
Here is a simple event structure that should do what you want.
I strogly recommend you read this (https://www.ni.com/docs/en-US/bundle/labview/page/caveats-and-recommendations-when-using-events-in-l...) if you plan on using anything more complex than this.
Message 5 of 14
(5,397 Views)
I couldn't open your file I have version 10.0.1 is there another way you can post it or i can access it?
thanks
Message 6 of 14
(5,361 Views)
Saved for version 10
Message 7 of 14
(5,357 Views)
That's cool but how can I do this with a boolean led using leds to indicate which button has been press? I can't get the LEDS to talk to the case structure and thank you for your time btw
Message 8 of 14
(5,353 Views)
So four LEDS to respond to it's own arrow key
Message 9 of 14
(5,351 Views)
Also how can I add more options to the case structure. I can only choose true or false from my options
Message 10 of 14
(5,346 Views)
