How to program labview to output continous voltage using NI PCI-MIO-16XE-50
I am an undergraduate student working on a research project. I need to program a labview block diagram to output continous voltage using DAQ NI PCI-MIO-16XE-50. I am new to this and having problems with formulating.
For example, if i need to output 4V, how to output 4V from the DAQ.
I know that there are 2 channels for output. But having problems figuring out which pins to use as well.
If there are any examples,tutorials or whatever hints i could get in order to solve this, that would be great. I am simply confused and wondering where to start.
Thanks in advance.
Confused undergraduate student
(3,122 Views)
Here is an example of how to do some basic analog and digital communication. Since you need a 4V signal you are going to want to use Analog Output.
http://decibel.ni.com/content/docs/DOC-15408
Product Support Engineer
(3,099 Views)
thanks
(3,075 Views)
