How to program labview
Excuse me I am programming in labview an i2c sensor but I don't know how to program it in labview please help me
Message 1 of 13
(5,911 Views)
Do you think you've provided enough information in your question for someone to be able to help you?
Message 2 of 13
(5,898 Views)
Are you new to LabVIEW, the sensor or both?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 3 of 13
(5,883 Views)
How are you interfacing with the sensor?  You need to know that before you can start writing anything.  Maybe something like the USB-8451 or USB-8452 would work for you.
Message 4 of 13
(5,878 Views)
The sensor has two pins one for the data and it is named sda and the other is clock and named scl my problem is that there are blocks in labview that corresponds to sensors working with i2c interface but I don't know how to use them because they ask for address of the sensor how many bytes I want to read and several things
Message 5 of 13
(5,831 Views)
Accepted by topic author zuzu12
You might want to use the SPI and I2C Driver API from National Instruments:
https://www.ni.com/en/support/downloads/tools-network/download.spi-and-i2c-driver-api.html
Hope that this helps,
Message 6 of 13
(5,811 Views)
The sort of information you are asking about should be in the sensor documentation.
Mike...
LabVIEW Champion
Message 7 of 13
(5,800 Views)
Ok I will check that thank you
Message 8 of 13
(5,756 Views)
I think it can be the solution thank you
Message 9 of 13
(5,751 Views)
I need a help in programming a continuous servo and they told me I should use PWM. Please can you check the code that I made, is there anything else that I should add?
Message 10 of 13
(5,691 Views)
