How to program the trriger mode of PCI-5114, include normal and auto mode,not the trriger type.
I want to use PCI-5114 to collect laser ultrasonic signal, trigger mode is set to normal trigger, but in the ni-scope attribute node only automatic mode, do not know how to program to normal mode, please help me! Thank you
(2,024 Views)
I use the PCI-5114 oscilloscope acquisition card to trigger the acquisition signal through the external trigger. In Labview, how to set its trigger mode is the normal mode. Only the automatic trigger mode in the attribute node of ni-scope does not know how to write the program block diagram of the normal trigger mode in Labview. Please help me. Thank you.
(1,970 Views)
