How to program two solenoids where when one is active the other cannot be
I would like I someone could give me sample could or a picture of sample code thanks
(2,458 Views)
Hi marysville,
Perhaps you could start giving more information on how you plan to control the solenoids. What NI Hardware are you using to control the solenoids? Are you using LabVIEW software as well? If so, what LabVIEW version you're using? What is your solenoid's technical specifications? What LabVIEW you used?
Can you post your LabVIEW code if you have attempted on this problem?
Warmest regards,
Lennard.C
Learning new things everyday...
(2,431 Views)
