How to programatically build a cluster to identify the data type to read from a binary file
I am using Labview for data logging purposes building my own data logger for binary files.  I want to embed an identifier of some sort in the header of the file such that I can take the identifier and build a cluster to pass in as the data type for reading a sample of data from the rest of the file.  This includes nested clusters in the cluster.  If anyone has any experience the help would be appreciated.  Thanks
(4,275 Views)
You cannot programmatically build a cluster at run-time like that. That would require being able to change the code at run-time, and you cannot do this since an application cannot modify itself. Scripting will allow you to programmatically build a cluster, but it's not designed to be used in the way you're envisioning.
It sounds like perhaps a polymorphic VI would be better suited to what you are trying to do. You would write a VI to handle each of your possible formats and then you can use a case structure to pick out which VI to run to read your file based on the identifier in the header file.
(4,248 Views)
Have you considered an XML implementation? You could flatten LabVIEW Object data as XML strings, which in turn will be read into LabVIEW by providing a reference data type. There are built in XML schema VIs in LabVIEW. There are also a number of 3rd party libraries, like GXML, if you prefer a different type of organization and parsing algorithm.
Cheers,
Patrick Corcoran
Application Engineering Specialist | Control
(4,217 Views)
