How to programatically create array by graph
Hi
I would like to create 2 of 1D array by programatically draw line on XY graph. Could anybody help me?
MS_CJ
(3,911 Views)
Hi MS_CJ,
you can use a for loop to create arrays. Which values do you need?
Mike
(3,909 Views)
Hi MS_CJ,
   what you want is that the user draws something on the graph, and this is converted to an array?
graziano
(3,907 Views)
Hi Mike S81
I want to build the look-up table by drawing characteristic curve of machine into table instead of plotting each them.
MS_CJ
(3,903 Views)
Hi Graziano
Yes, your understanding is correct. Could you help me?
MS_CJ
(3,899 Views)
Hi MS_CJ,
attached you will find a short example. You have to add an offset for the position of the xy graph, but it shows how you can do it.
Hope it helps.
Mike
(3,888 Views)
Hi Mike S81,
Thank you very much for your example.  It meets my need.
MS_CJ
(3,879 Views)
