11-12-2020 09:23 AM
On my desktop, I have a shortcut to "Abort All VIs.vi". It has "Run when opened" turned on. Inside it does this:
I use this:
11-12-2020 09:50 AM - edited 11-12-2020 09:52 AM
I'm guessing this is to do with something I don't understand about the context of these VI's execution, but neither are working for me in a test- I launched a bunch of a re-entrant vi (basically just a vi that waits) asynchronously. After which while theyre counting I run your stop/abort vi's and the reentrant vi's are still counting...
what am I missing?
thanks for sharing your code and the advice!
edit: spelling.
11-12-2020 10:02 AM
what am I missing?
edit: spelling.
All VIs in Memory will NOT return clones...
Stopping clones is more complicated. How complicated? Read back a bit. I think it's explained earlier in this thread (a few times?).
11-12-2020 01:44 PM
I use this:
I made this VI, then opened up a project and started running some VIs to test it out. I ran my "Abort VIs" VI but it wasn't doing anything... I realized it was aborting itself on the first iteration of the loop 😄
Closing and reopening put it farther down in the context list and then it worked as expected. This will surely come in handy!
11-13-2020 02:50 AM
I use this:
This will abort all VIs in all contexts. Some contexts are running LabVIEW native processes, and they shouldn't be stopped!
It will abort itself before completion.
This won't abort clones!! You need much more code to (somewhat) achieve that, see my previous post. This also won't abort "call and forget" clones. That issue is still pending (e.g. no solution afaik).
