How to programatically set and save shortcut menus in to a control?
I thin my problem is that im trying detect the case in a separeted event structure, I detect activation in one event strcuture, then go to a case strcutrue when the shorcut activation fires, and then (inside the case structure and in a separated time structure from the frist that triggered activation for shorcut) I weit for selecction. You mean that if I w8 for the selecction in the same Event structure than the rest of the user interface that wont block my program rigth?
Message 11 of 12
(732 Views)
As long as the menu is open, yes. This is one of the reasons that I recommend that the GUI be a separate process -- so it doesn't screw up the timing for other things. You'll discover a lot of other benefits on your own.
Check the link in my signature.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 12 of 12
(722 Views)
