How to programm a 2d crosscorrelation
I have two intensity plots with the same number of x,y pixels. I would like to know how are they correlated to each other e.g. if the intensity in plot A decreases then what is happening in plot B.
The results should be also a 2D array to produce an intensity graph.
Thanks in advance
PS I use LabView 6.0 for Windows
(2,932 Views)
Since intensity plots are 2D arrays, you should use the array function to compare these plots. You can use comparison functions on the arrays, too.
Zvezdana S.
(2,932 Views)
