How to (programmatically?) change the name of the taskbar button for an executable
@daveTW wrote:
Hello all,
to show the problem, I made a VI and an EXE from this (LV2010SP1)
Ah, now understand.
Andrey.
Message 11 of 14
(1,451 Views)
Hello Andrey,
this is the solution! Bravissimo!
Greets, Dave
Message 12 of 14
(1,432 Views)
Accepted by topic author cpschnuffel
Hello all,
@Andrey: Thanks a lot for your suggestion: This got me on the right track!
The final malefactor is the "Allow user to minimize window" checkbox. You have to check this to get your window title as taskbar button name; otherwise you only get the name of the executable.
To avoid TWO taskbar buttons for the executable, you also have to uncheck the "Show front panel when loaded" option (by the way: you can also solve this by adding "HideRootWindow = True" to the executable's INI file, but this file is rewritten every time you rebuild your executable).
See attached image.
cpschnuffel
Message 13 of 14
(1,430 Views)
I thought your intent was to change the name that appears in the taskbar after the application has been built. ????
Message 14 of 14
(1,412 Views)
