How to programmatically find out if LV runs in program mode or in compiled app
I'm using LV 8.5 and do some measurements with a USB-DAQ. Since I have a compiled version the code is still growing. So I'm looking for a possibility to differ programatically between two exits. While testing, exit and return to the development system, and as compiled application, exit LV completely and return to the system (as it does with exit.vi).
(2,979 Views)
Application property "App.kind" is what you are looking for.
Test against "run-time system" value and wire to Quit LabVIEW vi.
André (CLA, CLED)
(2,975 Views)
Thanks andré for your fast answer, but I have problems to find this property "app.kind". All I found was "app.typ" and that's not what you described. I had a look to a property node --> application --> "typ", so do I look at the wrong area?
(2,950 Views)
Accepted by topic author deepearth
  Have a look at the image.
(2,946 Views)
Thanks AutoTEC, your picture shows the difference between the languages, English: kind, German: Typ. Now the app runs fine.
(2,940 Views)
