How to programmatically minimize and maximize a LabView 8.5 program
How to you programmatically minimize and maximize a LabView 8.5 program.  In LabWindows SetPanelAttribute (panel, ATTR_WINDOW_ZOOM, VAL_MAXIMIZE); does it.
I would like to run the program for a period of time, then minimize it to run in the background.  Then on an error, have the program maximize so that the operator can see it.
(3,093 Views)
Hi pknight12...,
use an invoke node with the reference from the vi connected to it. Select front panel -> open, connect the state you need.
Mike
(3,087 Views)
Mike,
That works.
Paul
(3,070 Views)
