How to programmaticaly set the window run-time position?
The window run-time position is settable in VI properties.  Is there a way to programmatically set the run-time position (i.e. a property node)?  I'm using LV 8.2.1
Dave
(3,929 Views)
VI>>Front Panel Window.Window Bounds.
You can also read the help page for the VI properties dialog to learn of more options (methods).
___________________
Try to take over the world!
(3,925 Views)
Of course; Window Bounds.   I just didn't see it.
(3,920 Views)
Dave,
I think you can use Open VI Reference.vi and a property node or two to get to these settings.
(3,918 Views)
