How to put Custom Scales in Driver VIs created by SIT
    I am using SIT to interface the Simulink model to Labview and port the same to Embedded Controller running ETS. I have four outputs from the Simulink model that gets mapped to four channels of 6733 Card on PXI chassis. All the signals from four channels are having separate scaling factors which are defined in MAX.The problem is the driver vi which is created is only capable of reading only one custom scale .There is a driver Vi created for IO called Initialize Analog Output.vi in which I manually add the custom scale name and max and min value in AO create Task.vi (DaqMx lib).My question is how to modify this vi to feed separate custom scale for separate channels ,as only one task is created for all the channels.
In nut shell I need to know how to add multiple custom scales for multiple channels for a card in the driver vi created by SIT .
Ansh
(2,456 Views)
Dear Sir,
            Kindly refer the following document for the same.
hope it helps.
Shreyas
Shreyas Hebbare
Shreyas Technologies
India
(2,412 Views)
