How to put a waterfall display inside the front panel ?
When you call a waterfall display from sound and vibrations toolset from Labview , the waterfall apears in a different window , not in your front panel .How can I put it in the front panel in order to print it with the rest of the front panel ?
LabView 7.1 -windows XP -
(3,539 Views)
You can use a subpanel control to put the waterfall graph in the front panel of your application.
I am attaching a rough example for LV 7.1.
Doug
Enthusiast for LabVIEW, DAQmx, and Sound and Vibration
(3,539 Views)
Thanks Doug for your answer,
It was not possible for me to open this example, ( I have LV 7.1 and sound and Vib. toolset) I know how to use the subpanel function to open one front panel inside another one, but the waterfall display is not a front panel of a VI, or is it ? if it is a front panel of a VI ,what is its name ?
(3,539 Views)
Sorry you were unable to open the example. What error did you get? In any case, I am attaching a screenshot of the block diagram of the example that I sent that shows how you can put the waterfall in the subpanel. The actual waterfall display is a VI that is called dynamically by the SVT Waterfall VIs. The VI is called svl_Waterfall Display.vi, and a reference to this VI is already returned by the Initialize Waterfall VI.
Doug
(3,539 Views)
Thanks Doug , this solve my problem.
(3,539 Views)
