How to put alphabet one by one that makes a word (string)?
I'm making a program which I choose an alphabet one by one in the run process, I only know how to put several string into 1 strings using concatenate strings , but it is only for before the program runs, is it possible to put alphabet one by one in the " run " process and combined into 1 output string?
(1,266 Views)
attachment file
(1,265 Views)
Accepted by topic author PULSE.Wannabe
You need an initialized shift register (anchored in the lower while loop) for the string, then append or not depending in the situation.
(1,246 Views)
