Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
How to put data (from texte file) in the Tab
jean-Leost
Member
07-03-2002
09:40 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I have a file with one line data.
I want to put the data in a tab with 5 colums and x line.
I attach a example.
Thank's
ni-help.zip 9 KB
0
Kudos
Message
1
of 2
(2,523 Views)
Reply
Re: How to put data (from texte file) in the Tab
Dennis_Knutson
Knight of NI
07-03-2002
10:08 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
You need to modify the input parameters in the Spreadsheet Sheet String to Array. For the delimeter, you need to specify a space. By default, the function uses a tab as a delimiter.
0
Kudos
Message
2
of 2
(2,523 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
