How to queue two waveforms in dynamic data
I am collecting two waveforms for voltage data via DAQ assistant. The output is dynamic data which I can view as two waveforms via a chart.
I am sending the retrived data to a queue for storage until a seperate loop can flush the queue and write the data to a measurement file via the Write to Measurement File vi.
When I retrive my measurement file only one of the two waveforms have been stored.
I have troubleshot the issue and have determined the correct data is going into the queue
(3,499 Views)
I'd recommend posting some code.  Are you passing in the two waveforms to the queue as an array of waveforms, or a cluster of waveforms?  Without seeing the code, it is just a guess as to what is going on.
(3,495 Views)
Thread was continued here in the duplicate post.
(3,480 Views)
