How to quickly document code with wrapping text rather than a long line
If I want to document a tight region of code, I get frustrated that I have to play textbox resizing games after I finish writing all the words I need. It would be great if there were a way to define the region where text should wrap and then start writing. Has anybody found a workaround for this?
(5,135 Views)
Oops, well my post wasn't really so helpful since you are already doing that.
Bill
CLD
(Mid-Level minion.)
(5,105 Views)
Accepted by topic author BenGTD
I just make lines in my text by using Enter or Shift+Enter depending on your options.
Another way would be to create a small amount of text and resize it.  Then you put in the rest of your comments.
You could also make a VI with just the resized text, put it in your user.lib, and add it to the pallets with the "place VI contents" option.
(5,080 Views)
Thank you. Good to know the documentation text box struggle is real.
Option 1. Yes - small text resize has been a solid go-to for me.
Option 2. The enter approach is good as long as I never plan to make changes to the text.
Option 3. All documentation text boxes aren't the same size. It may be more effort than benefit gained.
(5,069 Views)
You could write it outside of the tight region and place an arrow.
Maybe it's even better to make the tight section and comment a sub-vi of its own, then place shouldn't be an issue. 🙂
/Y
Qestit Systems
Certified-LabVIEW-Developer
(5,024 Views)
