How to re-autoscale a XY Graph after manual zooming?
i have a dialog-window that shows an XY-graph. Using the "Graph Palette" i can zoom into the displayed graph.
But how can i return to the original displayed graph after using the zoom/move functions?
Thx
(2,910 Views)
Hi One,
you can switch on AutoScaling (atleast once). Or you can set the axis scale with the default values. All that is done using property nodes…
(2,908 Views)
What is the name of the Autoscale-property?
I only see "Autoscale-Delay" in the property-list.
(2,903 Views)
Accepted by OnlyOne
Hi One,
graph axis is controlled by the axis properties as described in the help.
Read the help for "Scale Fit"…
(2,899 Views)
