How to read 32 bit depth .bmp image
How to read 32 bit depth .bmp image using LabVIEW?
@nk
Message 1 of 17
(5,905 Views)
Is "read BMP file" command not working, please?
Message 2 of 17
(5,877 Views)
http://zone.ni.com/reference/en-XX/help/371361K-01/lvpict/read_bmp_file/
Thoric (CLA, CLED, CTD and LabVIEW Champion)
Message 3 of 17
(5,872 Views)
 This won't work for 32 bit depth images. Yes the read bmp file.vi i s not working for my image. When I am saving it in paint it changes to 24 bit then it works perfectly.
@nk
Message 4 of 17
(5,857 Views)
I have no clue yet. But you may consider to supply the image and the error you see. ("not working" is vague)
Message 5 of 17
(5,852 Views)
A "standard" image, by which I mean an image type most typically encountered, stores image data in RGB format with 8 bits per colour, making them 24-bit images (24bbp - bits per pixel). A 32-bit image normally includes an additional 8 bits for the alpha channel, but in BMP files this format is complex (see wiki article), and it appears the LabVIEW Read BMP function does not support it.
Do you have the IMAQ toolkit? I can't test the theory, but perhaps the IMAQ functions for reading image files are more advanced and can read your images?
Message 6 of 17
(5,844 Views)
I am attaching the error message  but when I am trying to attach the picture it is saying unsupported format.
@nk
Message 7 of 17
(5,842 Views)
archive it, e.g. into ZIP or 7ZIP
Message 8 of 17
(5,838 Views)
I will try this .
@nk
Message 9 of 17
(5,837 Views)
hi @nk,
could you post an example 32-bit .bmp file?
Message 10 of 17
(5,832 Views)
