How to read .Csv file
Hi
I have a .csv file. i want to read this csv file and want to display only 2 column elements in a for loop and i don't want to display first two element of 2nd column(only from third to last).
Note:no. of row and column may change.
(2,844 Views)
Hi Risuraj,
@Risuraj wrote:
Hi
To read a CSV file you can use ReadDelimitedSpreadsheetFile.
Then use ArraySubset (or IndexArray) to get your 2 columns of interest.
Then use IndexArray to get the "2nd column" and ArraySubset to get all elements "from third to last"…
What have you tried so far? Where are you stuck? Do you get any errors?
(2,814 Views)
Can you show us what you tried yet ?
There is a VI called "Read delimited spreadsheet". Try to display all the columns first and then select the data you need with "Array index", "Array subset",...
Yddet
(2,812 Views)
i have done till this point.i want to proceed in this way.
(2,803 Views)
Give this a try.  I am using Array Subset to remove the first 2 rows.  After that, you can autoindex the array and it will index on your rows.
(2,799 Views)
