How to read MATLAB imported data from a .tdms file?
Hello!
I want to read MATLAB imported data from a .tdms file. The original MATLAB .mat file contains three structs A, B, and C. Each struct contains dozens of fields, and each field contains one-dimensional or multidimensional data. After importing LabVIEW NXG, a .tdms file is generated, and three stucts are imported into three clusters. There are six channels in total, namely A, A_Index, B, B_Index, C, C_Index. I read the example and tried many controls, but I still can't figure out how to read the data accurately.
Any help would be much appreciated.
(2,437 Views)
The new MAT files are actually h5(hdf) files underneath. I don't have NXG, but you need to import correctly, separate the structures, and then save to to TDMS.
mcduff
(2,417 Views)
