How to read QR codes from pixel table
hello.
I have found a program that generates big QR codes as a pixel table.
sometimes, the QRcode somehow cannot be read. Thus I would like to verify every every code
Do you have any idea of a tool that can help me about this?
please find joined a VI dontaining the datatype returned by my program.
this is boolean table, but it can be images as well (1 pixel per QRcode bit)
thanks in advance for your help
Pierre FCentum TNS, Grenoble
Certified LabVIEW Associated Developer
(3,592 Views)
Hello Pierre,
I am not sure what is your problem here ? Is it only about decrypting QR codes ?
If yes, maybe you can try the application given on this topic : https://forums.ni.com/t5/LabVIEW/qr-code-reading/td-p/3190978
Maxime L
Certified LabVIEW Architect
(3,524 Views)
hello maxime_L
I can't use this code in your link  because I don't have NI Vision.
Is this possible to use something else than NI vision since I don't need image acquisition, but just to decoding pixel table? (and vision costs 700 euro)
(3,517 Views)
Does anybody have a solution? Smiley Sad
I want to decode a qr code from a boolean table, for example, the constant I send you as a picture below.
thanks in advance
(3,409 Views)
