How to read Serial Data from Arduino using labview VISA?
I have an Arduino Mega2560 card, I have a ultrasonic sensor, and I labview2011 software, I try to operate the sensor in the arduino serial port TX / RX, with supervision labview,
ultrasonic sensor: DYP ME007TX
arduino Mega2560
how?
thank you
Message 31 of 143
(14,938 Views)
This example reads an analog sensor and plot the value in a VI
Message 32 of 143
(14,873 Views)
thks M, but i have labview 2011,i cant't open your files, do you have a picture of programme in labview,
Message 33 of 143
(14,815 Views)
Hi.
I am practicing for the first time with the Arduino (Uno),trying to receive data from the analog 0 input.
I took a vi from one of the formers here in the topic (TempMon.vi) and made some changes to remove the concave to temperature section.
In the loop , I left basically with the VISA read-> FRAC to string-> Graph .
Now I see that the strings are not constant (I put a constant voltage). most of the time its the same but is can varies .
In the Arduino program, the output looks OK e.g. constant.
Attached, my VI.
Any suggestions?
Message 34 of 143
(14,754 Views)
@sagi4422 wrote:
Hi.
Attached, my VI.
Any suggestions?
So what are you asking?  Are you just asking for a review of your code?
thanks.  🙂
Bill
CLD
(Mid-Level minion.)
Message 35 of 143
(14,740 Views)
Nice example.  Well done.
Message 36 of 143
(14,597 Views)
I am trying to receive data from a microcontroller using RS485. I am using the NI USB to RS485 with 2 ports (http://sine.ni.com/nips/cds/view/p/lang/en/nid/14584). The port LED is flickering showing that data is being read, however I cannot see any data on the front panel indicator. I have tried your arduino solution to no avail. What could be the problem, please?
Message 37 of 143
(14,509 Views)
I had same problem to measure the temperature from serial monitor of arduino on labview and i am using this vi but it read only first value and show it every time it wont change conntineously. please help me.
Thank you.
Message 38 of 143
(14,439 Views)
This article presents a procedure for reading the analog ports of Arduino UNO R3 board , on which a Joystick shield was installed. The analog data are related to the position of command and can be monitored from the front panel of our program , for which we use serial communication.
https://decibel.ni.com/content/docs/DOC-33281
Message 40 of 143
(14,167 Views)
